histogram with just some columns of a table
i wanna get a histogram from just some columns of a table (4 -6 -.....22)
Message 1 of 19
(4,372 Views)
It seems rather pointless to always attach oversize images that seem quite unrelated to the problem. The table terminal is not even visible!.
You want a histogram for each of the columns or for all selected columns combined? What is giving you problems?
Message 2 of 19
(4,355 Views)
i attach the image just to give a simple idea about the issue.
i want to get in the histogram just some columns of my table(exactly 4 & 6.....22),and the histogram is 2 column clustred ,the 1st one represents what i said before and the 2nd one the average value of each column(again just 4 &6....22)
Message 3 of 19
(4,349 Views)
Hi achfire,
 Nice to see you after long time,,Smiley Happy  .For histogram plots ,please refer to the attachment.
Srikrishna.J
Srikrishna
Message 4 of 19
(4,336 Views)
thanks a lot srikrishnaNF ur always here for help.
about the histogram i know exactly how to do that,i'm looking for how to get just some columns of the table to make a histogram from them
Message 5 of 19
(4,316 Views)
A table is just a 2D array of strings. To get a column, you use index array with toe row  index discunnected. To get a subset of columns, you would use a FOR loop, autoidenxing over an array of column indices. Try it!
Message 6 of 19
(4,307 Views)
i tried index array but maybe in a wrong way
instead of getting 2 column clustered in each value(candidat & moyenne) i get histogram 3,4....11
Message 7 of 19
(4,285 Views)
Sorry, I don't have the office toolkit.
You need to simplify your example in order to get better help. A loarge oart of your code is very convoluted and barely readable.
  • Make sure your table has reasonable default values (run the VI until it contains data, then make the current values default).
  • Delete everything except the table and the histogram related code.
  • Save under a new nsame and attach it here.
  • You still have not explained what kind of histogram you want from ll the columns. Explain exactly want kind of result you would expect from the default data.
Don't continue to clutter your post with oversized and meningless images. It is very distracting.
Message 8 of 19
(4,274 Views)
for the table, i don' have any problem,it's fulled with data that i want.
about the histogram: i'm trying to get a comparison between some values of a user(row) with the average.so the histogram has to have  in the x-axis 10 values (E1 -E2 ....E10) and in E1 i want to see 2 column clusters.the 1st one represents E1 for the user and the 2nd one represents the average of E1 of all users(all values of this column).in other words i want to make a histogram for just some of columns of each row
i removed some sub-vis, and i left important things.
i really hope that u figured what i have to fix,because i tried many solutions.
Message 9 of 19
(4,267 Views)
There is no data in the table of the VI you have attached. It is all blank.
Message 10 of 19
(4,262 Views)
