hmi wizard for indicators inside cluster array
I am setting up a config screen for use with the DSC and tag engine. I have an indicator and analog value inside a cluster array. Can you use the hmi wizard to make unique conditions for the indicator in each array element?? or would I have to use a sub vi to write the values to the elements inside the clusters??
(2,941 Views)
The simple control in the cluster or in an array will not have a way to invoke the HMI Wizard to create simple HMI code because the control turns into a more complicated control type. Using a sub vi to unbundle the cluster should be a workaround for this application.
Remzi A.
(2,941 Views)
