homing switch causing motion control problems
I am controlling a dome for a telescope. I have a home position switch and motion control using one of NI's motion controllers. Everything works fine except for one bug. The dome just goes around and around. I can run a Home type reference search and it works fine. But if I command a position that runs through the home switch zone the dome stops moving. If I hit the command a second time it runs right to the correct position.
So why does the home switch stop the motion if I am not doing a reference search. Should I be using some other form of referencing?
Dave
David A. Taylor
(2,616 Views)
Do you have the home switch also configured as a limit switch?
What motion hardware are you using.  In addition to home limits, the ni cards often have a + limit and - limit and also a software limit, these can be configured via the api or in max.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,610 Views)
