host to fpga transfer
hi, I wanted to know if it is possible to have some help about the realization of an optimized VI that acquires data from a host, through FIFO saves them in a circular buffer implemented with the DRAM memory of the fpga. Thank you
(1,020 Views)
Hi marco,
two comments:
  1. It would help when you would provide your current un-optimized VI/project.
  2. It would help to put the message text NOT into a code section…
(1,018 Views)
