how I can have the three curves with the exact time stamp
I have a problem in the display of curves, I want each curve shows the value in time stamp. What i get it is that the diagram shows curves with a false time, it's fixed in the first time stamp.. what shoud i add on the bloc diagram to correct the program.
(2,819 Views)
Hi marmara,
this is how it looks like when you want to plot 3 values over the same x axis of a chart:
(2,807 Views)
Hi GerdW, thank you but what i want is to have in the diagram Y=f(X) with X is the time stamp and Y is either the temperature or humidity or sunlight! but the problem is that the time is wrong it's not the time stamp displyed. How can i adjust it to shows me the true value of time in the diagram?
(2,800 Views)
Hi marmara,
simple example of displaying a random value of time on a chart:
(2,796 Views)
