how I extract colors from Rubik's Cube ?
I need your help, how I extract colors from Rubik's Cube ?
I'm newbie. I only have basic knowledge. But I want to build a Rubik's solve robot.
Thank you for help.
(2,526 Views)
Hi Natapan,
To extract those colors you have to peel off these colored stickers…
First try to develop an algorithm and setup you want to create. (It might help to watch videos on Youtube to learn how others solved that problem. Most use a camera.)
Then get the required hardware and build your machine.
Then start with learning LabVIEW.
Then develop your program to solve Rubik's puzzle.
(2,497 Views)
Have you tried LabVIEW's "Help" system?  Click on Help (on the Menu bar), choose "LabVIEW Help", and type, say, "Color" on the Search Bar.  See if anything looks "interesting", then read about it.
Have you seen any LabVIEW "objects" that seem to have a Color?  Say the Boolean LED Indicator?  Have you put them on a Block Diagram and right- or left-clicked them?  Does anything "interesting" happen?  Have you done any exploration, or testing?  [Things you find out or discover for yourself will "stick" with you better ...].
Bob Schor
(2,483 Views)
