how can I avoid the inclusion of the kernel32.dll in the installer?
Dear Members
Does anyone know how to prevent the inclusion of the Kernel32.dll in the Installer?
The problem is that I am using WINAPI calls. Doning so forces the installer to include
this DLL into the project. This file will copied into the installer package and reside
inside of the program folder after installation.
I have programed the project with LV 8.5 Windows XP and compiled it for 2000 or later.
The same happens if I do so for XP or later.
Is there a way to avoid this binding?
Kind regards
With kind regards
Martin Kunze
KDI Digital Instrumentation.com
e-mail: martin.kunze@digital-instrumentation.com
Tel: +49 (0)441 9490852
(3,147 Views)
I found this two threads - I hope this helps:
http://forums.ni.com/ni/board/message?board.id=170&message.id=148047&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=45644&requireLogin=False
With best regards,
Ralf N.
Applications Engineering
Germany
(3,117 Views)
Accepted by topic author M_Kunze
Just for historical purposes, there are two very good workaround:
Enter only the library name if the library is in the search path of the system.  See the Call Library Function Dialog Box Help.
Use Specify path on diagram for the Call Library Function Node, and enter the system dll's path in a constant.
Message Edited by chris.b on 04-01-2009 05:10 PM
Chris Bolin
LabVIEW Partner Program, CLA
(2,903 Views)
