how can I change the logo on titlebar while runtime
....is it posible to change the title bar logo modification ? if yes please inform the procedure..
(2,762 Views)
If what you mean is the text in the titlebar, the answer is yes. See attachment.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,762 Views)
sudhakar wrote in message news:<506500000008000000328F0000-1042324653000@exchange.ni.com>...
From build application or shared library (Dll)-New script, select
application settings, then check custom icon and select your own icon
file. After application build, new logo will be used .
(2,762 Views)
