how can I chose a printer to print my graph?
hi,
how can I chose a printer to print my graph? At the moment I can print only with the standard printer, but I want to chose different printers, because I have three printers. How can I solve this in Labview? Is there a property in the property node or a VI?
(2,791 Views)
If you have the Report Generation Toolkit you can use the Qurey Available Printers.vi to get a list of printers configured for your PC, write a vi to select from this list, and pass that printer to the Print Report.vi.
If you don't have the toolkit, you can use the property node (located under the Application Control palette), Printing:Available Printers property to obtain a list of printer names programmatically, then write a vi to select from the list, and pass that printer to the Printing:Default Printer property to set the default printer in LabVIEW programmatically.
(2,764 Views)
Hi
thanks for your help, it works now!!
labprog
(2,754 Views)
