06-20-2005 06:59 AM
06-29-2005 04:08 AM
06-12-2008 06:08 AM
I read this thread really very enthusiastic query for me also.thats why i am also interfering in this thread.I have achieved to transfer data from FPGA to RT @6.4 MBps using DMA FIFO deterministically.I also transfer data from TCL to NPL through local shared variable with RT fifo (not network).now my query is that i want to transfer the data using TCP/IP protocol to my host PC very deterministic way.at the lower rate i am able to synchronise to transfer data.
when i used higher rate (max=6.4 MBps),i have to increase the size of DMA fifo(RT side),and also RT FIFO(shared variable ).but my TCL loop will slow then there would be chances the lost of data from NPL to Host.
If my query is clear for you,feedback me otherwise i would explain in much more way.
Pratima
06-13-2008 04:56 PM
