how can I convert Hexadecimal string into a floating-point value
How can I convert Hexadecimal string into a floating-point value. For example,the Hexadecimal strings are D5 50 9A 44 ,the floating-point value  is 1234.526
thank you
(2,773 Views)
Accepted by topic author guoyu
Presuming you mean single precision floating point, this VI should do the trick
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(2,769 Views)
thank you ! But your software version is too new.I use labview 2011.I can not open that program that you give me.Could you give me the picture of Function Block Diagram.thanks
(2,759 Views)
thank you! got it
(2,747 Views)
thank you! got it
(2,746 Views)
thank you very much! got it
(2,745 Views)
