how can I convert an xy graph a waveform graph?
hi!!
Everything is in the title!! I've made an XY graph and I would like to convert it into a waveform. To create this XY graph I give only the coordinates of each point.
The image “file:///C:/Documents%20and%20Settings/TMR01/Bureau/1.JPG” cannot be displayed, because it contains errors.
(3,775 Views)
Hi
As far as I know this is not really possible with a built in function, you will have to do it yourself. In a XY-graph, XY-pairs are painted and connected. A waveform is defined by starttime, dt and the y-values. So if you want to make a waveform, you have to find a dt for the data in your xy-graph. This value will replace the x-value, as each y is at a defined x (yi = t0 + dt*i). In addition to that, you will have to set the y-values at the correct index, which obviously results in an array with zeros between the given values. To avoid this, you will have to interpolate the y-values between your given y-values.
Just an example:
xy-data (x/y): (0/2),(1/4),(1.5/3),(2.5/0)
This would result in the following waveform:
t0 = 0
dt = 0.5
y (before interpolation) 2,0,4,3,0,0,0
Interpolate the missing y values and you should get this waveform:
to = 0
dt = 0.5
y (after interpolation) 2,3,4,3,1.5,0
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,750 Views)
