how can I convert .int to .csv or other file so that I may salvage my data
My data are written or stored in a file with the extension .int and the headers are stored in a .int file.  At the end of data acquisition the files are combined to create a .csv file that I generally then open in Excel.  Problem: the program crashed.  I would like to salvage the data.  In the data folder are the two .int files.  How can I convert the .int data file into a .csv file outside of LabVIEW?  What program or application can I use?  Thanks!
Message 1 of 8
(5,539 Views)
.INT is a Borland Delphi extension but I'm not familiar with its structure.  If you open the file in Notepad is it readable or binary gibberish?  If it's human readable you should be able to create a conversion tool with labVIEW or any scripting language pretty easily.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 8
(5,532 Views)
Gibberish
Message 3 of 8
(5,528 Views)
Bummer.  I didn't find any file format details particular to .INT with a quick Google search.  It's tough to search for since INT is short for so many things (e.g. INTeger, INTernational, etc.).  You might try contacting Borland or peruse a Delphi forum for help.  Otherwise you could try using LabVIEW to read the first line, typecast it into different sized bytes and then convert those to strings.  By trying different parameters you may be able to convert it into something legible which would provide you with the key to translating it.
If you can, post a bit of the file(s) and perhaps someone here can help decode it.
Message 4 of 8
(5,515 Views)
Do you have a set of .int and .csv files which were successfully converted as an example?
Lynn
Message 5 of 8
(5,511 Views)
File size is 149MB.  I don't know how to split it in order to post it.
Message 6 of 8
(5,496 Views)
To Lynn,
Once the header and data files are converted to a .csv file the original .int files are deleted.  therefore I have .csv files from previous experiments but no associated .int files.
Message 7 of 8
(5,495 Views)
I could run a very abbreviated experiment, prematurely stop it, and send a much smaller paired header and data .int file.  I will need to wait until Monday to do this.  Please stay tuned, your responses are encouraging me to figure this out.
Message 8 of 8
(5,494 Views)
