how can I find largest cluster values from different clusters and display it?
Here I need to consider a cluster as an image(with height ,width,bitsPerPixel as parameters) and I want to blend more than 3 images(find the one with the biggest size) and display only that image(cluster) .
(3,205 Views)
are you talking abt processing a image and finding something? if so post some images? if not explain it a bit more clearly.
(3,203 Views)
not an actual image, the cluster is containing the image parameters, describibg an image; like height(numeric), width,bitsperpixel. all numeric
there are more than 3 clusters of this sort.
 how do i sort the clusters on the basis of (height*width) and also find out which cluster has the greatest value.
And then display the cluster, or give an output
(3,186 Views)
you can try something like this
(3,177 Views)
hey
thanks for the attempt, but i guess u got me wrong
you took 3 element in a cluster.
i have to take 4 clusters having three elements each(the clusters are of same data type)
Of those 3 elements , in each cluster, i have to find out which cluster has the product of two elements greater(the two elements are known say height and width)
now , I can find out the greates product of the three, but how can I also find out which cluster it belongs to.
thanks again
(3,174 Views)
When they are of same data type why not use an array?
(3,165 Views)
Check this
(3,164 Views)
