how can I find the minimum in real time
I 'am doing some type of sensing mechanism. I that the data is step count versus intensity. So I want to record the minimum in real time from. Please kindly help
(4,431 Views)
Use the Max & Min vi in the Comparison palette.
(4,425 Views)
Hi perumpadapu,
you should have learned by now to provide some meaningful example (data)…
There are functions to detect minima: ArrayMinMax, "smaller than" comparison, PtByPtArrayMinMax, MinMax comparison, ...
It all depends on your data!
(4,421 Views)
My data is a two dimensional array coming from a graph, step count versus intensity(Volts). So I want to find the minima in reflected intensity in time. If you can advice a solution ,it's very helpful to me.
(4,373 Views)
Hi perumpadapu,
a graph is a data sink, so it can't be the source of your data…
Can you attach a VI containing a 2D array of typical data? LV2011 preferred…
(4,354 Views)
yeh, I will send it
(4,342 Views)
