how can I give a range mens some number is less than a number and greater than other number.
how can I give a condition for a number like this
               1<x>2. TO a condition to the  case loop selector terminal for selection .I expect help
(2,301 Views)
You mean you ' want' help. Expecting help is actually a rather rude statement.
Just use the In Range and Coerce function.
(2,297 Views)
In the case selector, write "1..3" for all integers 1 <= x <= 3
(if using floats it'll get rounded to an integer, so not the optimal solution, then you'll need In-range and coerce)
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,282 Views)
