how can I manipulate a array
Hi everyone, i have a little problem here.. I'm acquiring a signal that is in one moment diferent of zero and in another zero ( like a counter), However, i'm wolud like to do is:
when the signal is not equal of zero, do some calculation and store the values in to a array, and in another moment , if the signal is zero, store in the same array zeros.
(3,666 Views)
anyone?
(3,645 Views)
share ur code...
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,638 Views)
Hi renatao,
replace the "equal to 0" with "unequal to 0" and you're done...
Right now you do your calculations when the value is zero!
(3,637 Views)
here i doubt.. that he will ever gonna get zero.... and therefore always execute non-zero case...
(3,633 Views)
That is!
In the first moment, I'm separating the channels, and in another, i'm doing a comparison( if less then 2,5....) to separate the components in channel one...
then I will like to do the calculation, only if the value it is different of zero, and store in to a array, and if is equal to zero, store zeros in the same array.
(3,625 Views)
I think that is a easy problem to solve
(3,585 Views)
