how can I measure the time difference between spikes (interspike intervals)
I have used NI USB-6008 (DAQ) to sample a continous signal, after sampling I compared the amplitude of the resulted signal with a value. If the amplitude is greater than a specific value (threshold) then it can pass. Now I want to measure the time difference between the resulted samples. The samples look like spikes. (May be if I trigger a timer, then I can measuer the time difference, but I have not seen such a timer).
Thanks in advance,
Saraydin
(3,209 Views)
Depending on your signal you can use an edge seperation for digital signals or you can do continious analog acq and calculate the edges in software.  This all depends on the timing and what you mean by spikes?
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,207 Views)
Thank you!
I mean the Spike (in nervous system), for better understanding check this: http://en.wikipedia.org/wiki/Spike_train
(3,200 Views)
OK, then I would think about using continious acquisition on 1 or more AI channels since these are not digital signals and processing the data in a second loop.  The nervous system is not all that fast looks like spikes are 50us long and probably have sufficient recovery time to discriminate between pulses.
Paul Falkenstein
(3,174 Views)
Oops just occured to me that you are using a 6009 which is not very fast, 48ks/sec, this will not get you very much time resolution and you could have issues seeing much of a 50 us sample.  Another approach is to use the counter but you would have to preprocess the spikes to generate a trigger for the counter.
Paul
Paul Falkenstein
(3,171 Views)
Have you tried using the Peak Detector.vi?
PaulG.
Retired
(3,169 Views)
