04-24-2012 08:30 AM
Hi guys, I am working with an imaging measurement using Andor's EMCCD. It is generating files in the format of .sif.
I am making a labview based analysis software but labview doesnt open .sif file direcly. I am wondering how I can open this crazy .sif file using labview direcly?
It is basically a stack of multiple images files with some head files.
04-27-2012 03:12 AM
Hi Shuohuang,
I think what you need is this DataPlugin http://zone.ni.com/devzone/cda/epd/p/id/5955
This should allow LabVIEW to support SoMat Information Files (SIF).
Kind regards,
04-27-2012 04:10 AM
Thanks so much. I will get it a try very soon. The patch that Andor technical support provided is just very poor. Hope this one solves the problem
05-02-2012 05:01 AM
Hi James:
I have downloaded the data plugin and installed it. however, still dont know how to read the .sif file into labview.
It is basically an image stack file which I would prefer to load it into labview as 2d data arrays
05-04-2012 03:34 AM
Hi Shuohuang,
You normally open image files in LabVIEW in a way similar to this:
http://digital.ni.com/public.nsf/allkb/02971A30F5D8FC6986256A0A004F11A0
Or you can import them if they are one of these file types
http://digital.ni.com/public.nsf/websearch/DD7B2734795BDAF386256BE40067B6A0?OpenDocument:
I've never dealt with .sif files before and you say that it is a stack of multiple images so I'm not sure how the normal image functions will work with .sif files.
If you can post one of the files on here then I can have a play and see if I can figure out how we open them in LabVIEW.
05-06-2012 05:29 PM
There is a utility from andor that reads sif files. I think that it comes with Solis. I find it at program files\Andor Solis\Drivers\SIF Reader .
05-06-2012 10:29 PM
By "utility", I mean a set of Labview wrappered just wrappered dll functions. If you don't have it on your install, I am sure that Andor would provide it to you.
07-06-2017 04:52 AM
I am using LabWindows/CVI. Can you teach me how to open Andor .sif file using SIF.uri?
07-06-2017 09:58 AM
I have never used labwindows/CVI, unfortunately. Andor almost certainly has some examples in the install location that I referenced above. You should have a look at those and then just steal the code that does what you need (that is what I did). Not sure if this helps. Also, you might be able to get andor to autosave your data to a file format that you are more familiar with? J
