how can I play an audio signal using DAQ or other way?
I'm designing a Voltage control amplifier. as shown in the attachment, I have a speaker connected to the power amplifier but all i have is noise. I like to know how can I put an simple audio to my circuit. My audio input is generated by the function generator. I only have a simple labview program which control my voltage input as attached.
Message 1 of 13
(7,510 Views)
bump. helpp
Message 2 of 13
(7,473 Views)
i like to know how can i generate an audio input to my circuit. just a simple program will do. thanks
Message 3 of 13
(7,467 Views)
Can't you just use the WAV output VIs in the Sound palette and use your PCs sound card output?  Look in the examples if you need to see how sound output is done but playing a short wave file is pretty easy.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 13
(7,458 Views)
hi, thanks for your reply.
I'm new to labview and actually i dont get what you mean. i have learn how to Retrieve an Audio Signal from a .wav File from this website. http://cnx.org/content/m14771/latest/ but how do i actually output the audio signal to the device NI ELVISII?  can you guide me along or show me the link?
thank you! really appericate your help!
Message 5 of 13
(7,444 Views)
The last example is similar to what I was talking about.  It sends a generated waveform out through the sound card output of your PC that you can wire to your circuit input.  A better choice would be the Generate Sound VI found in the Example Finder > Hardware IO > Sound.  It's basically a simple function generator that outputs from you sound card.
If you want to use a DAQ card (Is that what ELVIS is?  I've never used it.), look at the Voltage Continuous Output.vi example (Hardware IO > DAQmx > Analog Out).  That one is like a signal generator that outputs from your DAQ cards analog out.
Message 6 of 13
(7,407 Views)
hi thanks for your reply.
just to comfirm, can i play a music signal file wav using the examples you show me?
anyway i will be trying out them tmr.. thank very for your help! cheer!
Message 7 of 13
(7,392 Views)
Sure you can.  Are you even looking at the examples???  There is one called Sound Player.vi in the Sound folder.  It takes a path to a wav file and plays it throught the sound card.
I just noticed I have a Sound File Play VI in my Sound palette (using LabVIEW2012).  That makes it even easier to output wav files but inside is just a DLL call so you won't learn as much as looking through some examples.
Message 8 of 13
(7,383 Views)
Sorry sorry, I didn't complete my sentence. I know how to play a wav file but not very sure how to output to my circuit board. Sorry to ask Stupid Q.
Message 9 of 13
(7,372 Views)
No problem, your questions are not stupid. I just want to be sure you're digging into the examples and learning from them (they're a great resource).
The sound card outputs should be good enough to drive your circuit.  Most cheap cards or built-in audio chips have a jack for line out and headphones (which is just the line signal through a buffer amp so you have volume control).  Either on should work for your purpose.  The line out should give you a volt or more at reasonable current levels. There also MIGHT be a low frequency filter on the output meaning that you won't be able to output DC levels or very slow (<20Hz) AC.
The jacks themselves usually have the signals (Left and Right) on the center conductors and the return is the barrel but you might want to look up your card's specs or probe the outputs before you connect anything to your circuit.
Message 10 of 13
(7,361 Views)
