how can I programaticly rezise a bitmap in order to fit in a picture control
Hi Alejandro-
I can not find a way to programmatically resize a bmp in LabView.
However - I found this suggestion in Developer Exchange:
Place an OLE object on your front panel (In ActiveX -> Container).
Right click on the container. Select Insert ActiveX Object
In the selection list at the top, select Creat Object From File, and
select the file. You can then resize the image on the front panel, and
the bitmap will be resized as well.
good luck
ben schulte
national instruments
(2,458 Views)
