how can I read a template and differentiate if it is a pattern matching template or a geometric matching template?
Hey all,
I would like to know how can I read a template´s information to know if it is a pattern macthing or a geometric matching template?
In my code, users provide templates and the algorithm must match them using pattern matching or geometric matching depending on the template.
At the moment I am doing it by including a P or a G in the name of the file, but I would like to avoid this and read the information from the file.
Any ideas?
Thanks in advance,
Esteban
(2,962 Views)
Accepted by topic author Arroyo
Hey Esteban,
you can use the VI "IMAQ Is Vision Info Present 2 VI" to reice the information:
IMAQ Is Vision Info Present 2 VI - NI Vision 2011 for LabVIEW Help - National Instruments
http://zone.ni.com/reference/en-XX/help/370281P-01/imaqvision/imaq_is_vision_info_present_2/
Take a look at the attached VI
Stephan
(2,937 Views)
Hey Stephan,
Thanks for the hint and for taking the time to prepare a VI.
Esteban
(2,929 Views)
