how can I record multiple signals for a long period of time?
Hi, everyone
I am new at labView I just recentlyl started using it. Right now I am working on this assignment
that I have to display en record six different signals comming up from a DAQ. so basically What I did
for my IV is placing a whileloop. Inside the while loop I set up the DAQ assistant and then I send that
to a split signal function in order to split the signas that are comming from the DAQ ( so those signals
are EMG1,EMG2, blood flow1, blood flow2, blood pressure, and AM stimulation) after I split the signals
I send each individual signals to a waveforme graph, but my problem is that I need to record those individual
signals for a long period of time every second for about 8 hours. so it will be really helpfull if someone can
guide me through this. Thanks
Regards
(3,114 Views)
Record as in recording the data to a file?
Have you tried searching?  Looked on the File I/O palette?  To get started quickly, you could use the Write Measurement File Express VI on the File I/O.
(3,101 Views)
With your while loop, you'd better use low-level VIs to write your data to a file. Please see attached...I've used text file function but if you need ta save a large amount of data, you may need to use binary file functions instead (nearly the same way to perform this whatever you chose text file or binary file function).
Best,
J.
(3,086 Views)
Hi - please visit our Biomedical User Group located HERE - lots of good information about using LabVIEW in biomedical applications, plus information on the free download of our Biomedical Starter Kit.
Thanks!
(3,066 Views)
