how can I remove the rectangle of an indicator
I would like to change the display mode of some indicators so as to make them look like the numbers and the strings displayed on the screen of the instrument in the photo below.
All this because I want to put this image in the background and drag the indicators to their corresponding places on the screen.
Could you please help me with this?
Thank you in advance.
(3,325 Views)
Just use an appropriate font.  Using fonts and colors, I bet you can get really close.  🙂
Bill
CLD
(Mid-Level minion.)
(3,313 Views)
use classic indicators ,Shift + right click on front panel
click on the bottom brush
select T from the rightmost corner and click on boundries of your control.
(3,308 Views)
But if you do that, the original numbers will show through.  I just can't read.
Bill
CLD
(Mid-Level minion.)
(3,299 Views)
Are you looking for a 7 segment Display? (The headline is a little bit confusing)
You can download the VI and can impliment it in your Code: https://decibel.ni.com/content/docs/DOC-4085
Maybe you also want to change the Layout: http://www.youtube.com/watch?v=qvhGH0TlCqs
If you only want to change the font, with could help you: http://digital.ni.com/public.nsf/allkb/5DCD38A1D020155386256DA9007DF506?OpenDocument
Please let me know if this helps!
Kilian H.
Applications Engineering
(3,231 Views)
HI,
Thank you for your responses. they helped me a lot.
Best Regards.
(3,106 Views)
