how can I rename a file programmatically?
I want to make a VI that rename a file, how can I do?
Message 1 of 14
(5,249 Views)
Use the Move VI in the File I/O>>Advanced pallete. Just give it the source file and destination file.
___________________
Try to take over the world!
Message 2 of 14
(5,247 Views)
Two methods are possible :
http://digital.ni.com/public.nsf/websearch/576434CD1B659EE386256F04006909AA?OpenDocument
regards
Marc Larue
NIF
Message 3 of 14
(5,223 Views)
A third method is to use "System Exec" vi and use the ubiquitos Rename Command.
An Example is attached It needs a file temp.txt in C:\
This is true renaming unlike other methods of copying and deleting.
Good Luck
Mache
Good Luck!
Mache
Message 4 of 14
(5,208 Views)
...and yet a fourth method, if you are a Windows user, is to make use of the runtime libraries provided by Windows. The attached example has been tested with LV 7.1 and Windows XP Pro...
regards
Bruce Smotherman
Message 5 of 14
(5,050 Views)
Hi does your rename.vi only work on the root c:\ drive?
Can I use the vi when my txt file in located in c:\document and settings\temp\filename.txt?
Message 6 of 14
(4,947 Views)
For the rename VI to work with a path that has spaces you need to place the path inside quotation marks, like this:
"c:\document and settings\temp\filename.txt"
___________________
Message 7 of 14
(4,942 Views)
Thanks again.
Can I use the same procedure (using SystemExec.vi) to delete a file?
Message 8 of 14
(4,934 Views)
Sure, just use the "del" command instead of "rename".
However, why not use the built-in LV delete file function (in the File I/O>>Advanced palette)?
This will be sure to work across platforms and OSes (for example, if the next windows OS doesn't support DOS commands).
___________________
Message 9 of 14
(4,930 Views)
Can i change the target path of a file and rename it in the same MOVE.VI?
Message 10 of 14
(4,748 Views)
