how can I run a vi after deploying into a PXI Machine
Hi;
I am wondering if there is anyone out there who knows how to run a vi after deploying into a PXI machine from my host machine. In my application, I have some vi's that are deployed into my PXI machine. My problem is that when I would like to start these vi's simultaneously after deploying them. My current approach is to call vi reference and then invoke-> run. However, since there vi's are being deployed from a host machine and they are running in the PXI machine, I don't know how to create vi reference with the path constant. In other words, how can I find out the path of my vi after being deployed into my PXI machine from the host.
Best Regards,
(3,033 Views)
Accepted by topic author SERDARSOYLU
When VIs are deployed onto a PXI Real-Time controller they are generally copied to a C:\ni-rt\startup directory on the controller.
Helpfully, this KnowledgeBase article talks about how specify and programmatically launch VIs on an Real-Time controller.
I hope this helps,
Fred Visser -- SystemLink R&D -- National Instruments
(3,009 Views)
