how can I sample 1 KHz asynchronous data using a PXI 6229
Yes. I would like to smaple the data deterministically. I know the frequency of the demodulated data. I was hoping I could trigger a clock starting on a rising or fulling edge of the data. Then use that clock to continue sampling.
Message 11 of 13
(850 Views)
I am not sure of the level of determinism you require, if it is high enough you may want to look into using a Real-Time OS. Otherwise you should look into some of NI's PXI Sync Resources
Synchronization Explained:
http://www.ni.com/white-paper/11369/en/
Reference Clock Synchronization:
http://zone.ni.com/reference/en-XX/help/370466V-01/mxcncpts/syncrefclock/
I think Reference Clock Synchronization would probably suit your application best. That way all of your cards will be referencing the back plane clock and will phase lock loop to it (essentially a feedback loop to maximize synchronization for each of your devices).
Message 12 of 13
(847 Views)
OK. Will try this.
Message 13 of 13
(838 Views)
