how can I select the time values of a signal and connect them to the y-input of a divide command?
I have an analog signal connected with a threshold peak detector. The counted peaks shall be divided by the total time of the recorded signal. My problem is, I don't know how to connect just the the x-values, i.e. the time component of the signal, to the divide command. I have no idea how to "split" the signal so that I don't have the whole signal but just the time in seconds as an output of the measured or filtered signal sub-VI, respectively.
Does anyone have a hint?
Thanks for your help,
Philipp
(2,335 Views)
Hi Phillipp,
do you mean you have a waveform and you want to get the components? In this case "Get Waveform Components" should work.
Mike
(2,334 Views)
