how can I use 9221 carrier along with NI 9162 USB to measure DC voltages using Labview DAQ
I am using Labview 8.0 with DAQ to get the readings for voltages using NI 9221 module and 9162 USB carrier. i can read the voltage but i'm not sure if it is ac or dc.
Could anyone help me with this
(2,529 Views)
Can you give more details about where your signal is coming from? Also, what exactly are you seeing when your graph the signal? Would you mind taking a screenshot of what you are seeing?
Chris Delvizis
(2,513 Views)
