how can I use Labview to process EEG signals
RESPECTED SIR,
                                     I am a b.tech student in electronics and communication. I am doing my major project in "BRAIN-COMPUTER INTERFACE". I like to know something that how can i use LABVIEW to process EEG signals. I am new to LABVIEW. I also like to know that what is the difference in using MATLAB and LABVIEW in processing EEG?
        Thank you in advance...
(3,283 Views)
Hi Sir,
You should take all those free online courses offered by NI. They are for free!
Basically there is no difference: both are programming languages which you can use to analyze data with your algorithms!
The differ in their appearance/syntax, but you will receive the same results when applying the same algorithm…
(3,276 Views)
Check the Biomedical Toolkit - http://sine.ni.com/nips/cds/view/p/lang/en/nid/211023
(3,274 Views)
