how can do with front panel?
In my VI, there are 2 graph. I tried to change the size of them by click the mouse. But how can i make the graph i click is front panel, and the other will be backward? Thanks
(2,714 Views)
Hi ha noi,
one solution could be to hide this one, which shall be go to background.
Mike
(2,700 Views)
hi mike,
If i alway change only 1 graph. It's no problem. But i want to change both. When i double click for the first graph, the second will be back ground, and when i click the second graph, the first will be background. How can i switch like that?
(2,691 Views)
Hi ha noi,
I've attached "Move Graph.vi" which adds property nodes to your code to change the visibility and position of the graphs.  You may need to experiment with the values wired to the Top property so the graphs are located exactly where you want them.  Hope this works for you.
Jennifer R.
(2,638 Views)
