how can i access one vi file functionality from another one vi file
i want access the one vi function from another one vi
example
test1.vi contains
add (x+y)
how can i call add fucntion in test2.vi
with regards and warm welcome,
Ramamoorthy S
(2,892 Views)
.Go through the tutorials that ship with LV. You will find the answer to that question as well as many other equally simplistic questions.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,889 Views)
i could not able to find the example can you please share the example for the labview 10
Ramamoorthy S
(2,881 Views)
Hi Ramji44,
you may refer to this short video:
http://www.youtube.com/watch?v=9IcifGHSNJc
if you want to call another vi, go to block diagram vi and right click it to show the function palette and choose "select aVi".
simple and easy...
(2,868 Views)
example
test1.vi contains
add (x+y)
Make add(x+y) into a sub-vi that's used in both.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,859 Views)
