how can i active x axis grid on a chart?
Hi,All
I was trying to activate the grids on waveform chart but  i couldnot find the x axis grid. if any one can help me please? there is some example , but i want to know how can i do it by myself.
simple vi is attached.
thanks.
(2,371 Views)
Accepted by topic author vanaddana
Right Click the graph and go to Properties, click the Scales tab. Click the drop down menu at the top and set it to X-Axis. Now go to the bottom and modify Grid Style and Color.
Hope this helps.
(2,358 Views)
Hi, string_theory
Thank you very much, it worked. the problem was that x axis was chosen by default and when i colored the maj&min grids vertical gride became active and now I selected Y and did the coloring metod the x grids came up!
(2,327 Views)
