how can i avoid to see the source code when any user open block diagram third time without password
i have a probelem regarding source code control. my problem is that  when user open block diagram of any sub vi in vi. i would like to make a such a vi which source code can not open after seeing the block diagram thrice time and i dont want to make password to see the block diagram so what can i do ?
give me the perfect solution for this type of problem.
(2,529 Views)
First protect you diagram
create a tap on your FP and create a picture of your diagram and put it on the second tapSmiley Wink
DON'T expect answers if you only want perfect one's
Greetings from Germany
Henrik
LV since v3.1
(2,522 Views)
Keep your users totally away from your source code by building an executable. Why do the users need to see the source code anyways?
(2,499 Views)
