how can i change analog waves into digital waves?
we had labview lab last week.. were doing fine if we have instructions unfortunately the professor will give us an exercise regarding baseband signals spectra.. were trying to download a trial software but we dont have any luck. the question asks for us to change analog waves into digital waves, measure the amplitude of the 5-th harmonic using spectrum analyzer.. i hope you can help me thnx..
(2,933 Views)
I think you should do homework by yourself. Even you find a failure, at least, you learn what should be avoid.
(2,908 Views)
That's very helpful KateB, thanks a lot !
(2,886 Views)
Try downloading the trial software again, and if it doesn't work again, contact NI. It's much harder to program in LabVIEW (note spelling) without LabVIEW.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(2,870 Views)
After you are successful getting LabVIEW on your computer, put together something to at least show us you're up for learning.  Then we can guide you to a solution that you've developed (mostly) on your own.  🙂
Bill
CLD
(Mid-Level minion.)
(2,855 Views)
