how can i choose programaticaly
how can i choose programaticaly this numbers.
0=(387ERE274138P)1=(2358840223)2= (4585JD947596A7)
0=(YIO68274138PO)1=(7223PPD7223)2=(9955GF75OI)
the first number after alphabet equal the numbers inside (....)as showing in up
someone can help me withe a sample
Thank you
(2,667 Views)
If I understand you right, your example is working properly. Are you just looking for cleaner code?
Attached is a quick modification that is a bit simpler to read. If this is not what you need, please clarify.
(2,667 Views)
Sometimes it is even easier to read or modify the code if there are no case structures and everything is visible at a glance. For example, you could index into an lookup array of strings. This is just one of many ways to do it.
Compare the code size (Vi properties...memory), it is 25% of your sample (2.1kB vs 8.4kB).
(2,667 Views)
Thank you very much Altenbach, for replying me
it exactly what i was looking for
thank very mach
(2,667 Views)
Thak you very much Altenbch
for giving me clean code, the sample it more better than mine
Thank you
(2,667 Views)
