how can i compile c code in labview at win98
friend i am using cin in labview but i am facing problem in compiling c code with labview. plz help me.
(3,109 Views)
Hi;
You need a C compiler in order to compile C code. Specifically to create a CIN, you need specific compilers. The following page includes a list of compilers that support CINs (See point 7):
External Code for LabVIEW - CIN / DLL - Starting Point
Instructions on how to build a CIN are here:
How to build a CIN code resource (.lsb file)
The main reference is the manual "Using External Code in LabVIEW", which
should be included with LabVIEW.
Regards;
Enrique
www.visecurity.com
www.vartortech.com
(3,109 Views)
