how can i create a sub-vi between two different block diagram in one graph ?
hello,
i need to create a subvi between two different block diagram in one graph
it is different programs and i want to Merge the two graph of them in one
help please
(2,452 Views)
Accepted by topic author waleedabdurhman
Hi wale,
I guess you want to "show two plots in one graph, each of them coming from a different subVI"?
- Please attach your current VIs and approach. Where do you have problems with?
- Do you use a chart or a graph?
- Which datatype is used by the data sources?
- Did you read the context help of your chart/graph to learn how to plot more than one signal in it?
(2,430 Views)
