I am using all DMA fifos,I want to acquire data from 3 AI modules upto 50 khz frequency.Sampling rate can be varied according to application.
please suggest me how should i allocate memory of my RT controller for those DMA fifos?I am also facing one problem, I am using 3 time deterministic loop with different different priorities,each time loop has one fifo where data is reading with polling method(first fifo.read=0 then againg fifo.read=remaining elements).and each time loop has been interact to host vi with global varibales.those global variables data update from normal time loop.can anybody suggest that this procedure is right or not.if my problem is not much clear i will again explaing my query with snapshot of my application.
Pratima
*****************Certified LabView Associate Developer****************************
