how can i delay a case structure
i am attempting to delay the execution of a case structure as a funtion time that is calculated via two controls on the front panel. i have tried using the hardware clock and using comparitors to provide a true/false comand to a case structure but is there any way to cause the case structure to be true in incremints of some time and remain true from some other time and then return false.
thanks for the help
(2,901 Views)
Not quite sure exactly what you are trying to do, but you can have a loop that does nothing but keep track of time and set a boolean control True and False depending on the time. That boolean can then control the case structure. Run the timing loop in parallel with the rest of your vi.
- tbob
Inventor of the WORM Global
(2,892 Views)
