how can i determine the sampling rate of my board
I am currently using the PCI-6014. I would like to know how fast this board is capable of sampling.can this value be increased or decreased from labview? i am using immediate Digital inputs and my analog signal look fine at low frequncies ( like 1-10 Hz). However when my input siganl increases to 100 Hz and even higher, it appears to be extremely corrupted. I tried adjusting the delay in teh loop but this not help.i am not sure what next to do in order to properly visulaize these high frequency signals.can i include some time base like an oscilloscope in order to see it better?
(2,498 Views)
The user manual is the best place to determine the specifications of your board. The datasheet for the PCI-6014 says the maximum sampling rate is 200,000 samples / second. Try searching the shipping examples for analog input examples. I suggest trying "Cont Acq&Graph (buffered).vi" to start.
Are you trying to acquire a digital input or analog input? If you are sampling a time varying analog signal, you should be connected to an analog input channel on your card.
Tim
(2,498 Views)
