how can i display a excel file generated by labview?
hello,
I'm looking for an exemple to display (open) a .xls file generated by labview after simulation but without use  the tookit report generation.
somebody knows how could I do this?
Any suggestions?
longar
p.s: i use labview 8.6
(3,357 Views)
Accepted by topic author longar
There is a example called "Write Table to Excel.vi" which shows how to use ActiveX to control Excel. Just use the Example Finder and search for the keyword Excel.
(3,355 Views)
There is quite large dedicated Excel thread with a lot of examples.
I'm curious though. If you don't have the toolkit, how did you create the Excel file in the first place?
(3,343 Views)
If you just want to open the file for viewing you can also jsut use the Open URL in Default Browser VI.
(3,323 Views)
"I'm curious though. If you don't have the toolkit, how did you create the Excel file in the first place?"
I use Open/ Create/ Replace File to create a .xls file and then the Write to Spreadsheet File. VI  to write the data in table format.
(3,299 Views)
