how can i do AD to DA with a delay value ? NI myDAQ
greetings.
i'm try to do acquisition and generate output voltage whit delay value, but when i put the delay the daq-assistant generate to me a error, i don't have idea why.
first i tried without delay value and i create de reconstruction of my signal without problem, but when i put the delay value the error arrives.
i'm trying with two codes, in the first i use de daq-assistant for generate my output, in the other i use the daq-mx but the answer it's the same.
too i did try with a "shift register" but the result it's the same.
the idea it's do the exercise with continuos samples for get a better reconstruction.
i need your help or some idea.
thx so much.
pd. add the two codes.
(2,138 Views)
Good morning, Hammer,
Please attach the image of the error that is appearing. Thank you.
Sincerely,
Mauro Vera
(2,123 Views)
