01-20-2010 09:03 PM
here i attached my block diagram ad an exmaple of trending which i did using excel. thank you
01-21-2010 09:25 AM
I am no guru but I would use a storage vi to store results to file updating each interation and put the values into a chart for realtime monitoring. A block could be added to append the front panel to a report when complete. I'll attach a small section where I am doing something similar. Somewhere you would have to address timing as well.
