how can i do with labview program,when i have 20 different values,and 1 want to add it with constant value.and how to get the results?
(2,714 Views)
Just add a constant to the array by using the "add" function. I have attached a simple VI that you can use.
(2,711 Views)
  • Why do the 20 values have to be different? The same code should work even if some are equal.
  • What do you mean by "get the result"? The result is available at the output terminal and all you need is a wire to get it where you need it. That could be an indicator, another operation, or even a hardware device.
  • What is the data type of the 20 values? An array? A cluster? A bunch of scalars? A waveform? Dynamic data?
(2,703 Views)
