I'm not sure if I fully understand your question, but I'll give a shot at what I think it is. If you want a button that can be pressed so that its states go from
"on, off, red., on, off, red." etc. you will have to use a bit of trickery. In this case it is best to use a picture ring to give the controls the image you want and place a boolean button OVER the ring control. Make the boolean control completly transparent, resize it to cover the entire picture ring, and make sure the boolean is ABOVE the ring by using "move to front". You will then have to have a loop checking the boolean button for a press, and then modify the pic ring accordingly and take your "control value" off of the pic ring. I'd suggest finding a work-around if you can, as this is a lot of work to go
through.
