how can i flip a certain bit in a bit stream?
i have made a hamming encoder and decoder and i want to evaluate the whole performance of the system so i want to to flip a certain bit (representing the effect of noise ) so the the decoder detecte this error and correct it , i tried to use a subarray to select one bit then compare it to zero (which i couldnt do mismatch data type)  , how can i fix this problem?
(3,171 Views)
You may use the Not Exclusive Or function. If I want to flip bit 1 in the U8=0xb10101010, I use the Not Exclusive Or function with 0xb111111101, and 0xb10101010 as input values. The result will be 0xb10101000. Set the bit you want to flip equal to 0
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,164 Views)
A little bit more logical is to use the exclusive OR function.  That way the bit you want to flip is a 1 and all the rest are zero.
(3,146 Views)
