how can i get from enum items name.
An enum contains the names in its type definition, and this can not be changed in run time.
Cut from the help of the Strings[] property: "If the string is an enumerated type control, you cannot write this property when the VI is running"
If you wish to edit the strings programatically I believe using a text or menu ring is the way to go.
Regards
//Martin
CLA
https://www.prevas.se/expertis/test--regulatoriska-krav.html
Message 11 of 25
(3,197 Views)
Hello Siva,
To add to the discussion, you may find the following KnowledgeBase article useful:
What is the Difference Between a Text Ring and an Enum?
http://digital.ni.com/public.nsf/allkb/79BA4505AE8C755E86256FB2000140B0
Message 12 of 25
(3,158 Views)
As it has been pointed out, you can't change the items in an enum at runtime. You can however enable and disable (gray-out) items at runtime. Perhaps that helps.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 13 of 25
(3,144 Views)
> download the OpenG toolkit, ...has a special 'enum to strings' VI
openg.org no longer exists. Support is now through lavag.org. See OpenG's Get Strings from Enum__ogtk.vi
Message 14 of 25
(2,581 Views)
> if ... you want to know the possible string values of an enum...
> download the OpenG toolkit, ... 'enum to strings' VI
See https://sourceforge.net/projects/opengtoolkit/ and Get Strings from Enum__ogtk.vi
Message 15 of 25
(2,590 Views)
Hi dwb,
thanks for bringing back this old thread!
What's wrong with the "Strings[]" property of the enum? No need to download any library of VIs…
Message 16 of 25
(2,596 Views)
@GerdW wrote:
Hi dwb,
Not sure if it is currently a complication but...
In RT (LV 6.1) the FP control properties do not work. Drove me nuts that I could step through the code and see it work but when run as an exe, no-workie.
Ben
Message 17 of 25
(2,589 Views)
GerdW,
I was really just updating information from another persons post because the URL and VI name have changed, but, if you want a list of the strings (or just the number of them) from a Block Diagram enum constant, that library function does it. I didn't want to create a Front Panel object just to be able to access the properties.
Message 18 of 25
(2,580 Views)
@GerdW wrote:
Hi dwb,
Or the 'Type def to strings' from the Variant function panel, no property nodes needed. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 19 of 25
(2,561 Views)
It is still that way.  It makes sense because there is no front panel loaded when an RT application is running.  Exceptions are the remote front panels and the cRIO-903X controllers that have a Display Port that you can enable.
Message 20 of 25
(2,552 Views)
