how can i get the serial and the tipe of model of the target i have inserted in the pc
hello
i want to find the type or model of the ni usb card and the serial number of it when i connected to the pc,
but how can i do it??can someone help me?
i have done something but the same error apears when i executate it!
THANKS!
Message 1 of 16
(4,220 Views)
Options are available in the Measurement I/O section. Try this property node.
Message 2 of 16
(4,212 Views)
well
if i put in hte way you have done, i have an error that is that the i/o in bad wired, and i cannot executate..
in the way you have done, i must say what device is, and what i want is to do it automatically.. do you understand?
Message 3 of 16
(4,207 Views)
You have to take the System property node and get the names of the device and then use the Device property node get the information you required.
Message 4 of 16
(4,202 Views)
hi!!!i take the name or type properly but i have an error with the serial number...the sserial number that appears in the measurament & automation...how can i take it???
Message 5 of 16
(4,198 Views)
do you understand me?
Message 6 of 16
(4,190 Views)
Can you post the VI that you made for reading the serial number?
Message 7 of 16
(4,186 Views)
 weel, i think is good..
Message 8 of 16
(4,182 Views)
Accepted by topic author alan4
Try the attached VI. it should help you, its working fine in my PC and I have got the info regarding my simulated device.
Message 9 of 16
(4,172 Views)
this is all
Message 10 of 16
(4,169 Views)
