how can i get this picture?
Accepted by topic author edongliang
Hello Edongliang,
Follow below mention steps.
1. Put XY or any kind of graph and chart on the front panel
2. On lift side amplitude scale right click on any digit
3. Select Duplicate Scale Option
This will create the duplicate scale on your Graph/Chart.
4. Right click on any digit of any scale(Select Scale whatever you want to shift on Right Side)
5. Select Option Swap Side.
I think this will work for you.......Smiley WinkSmiley Happy
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 11 of 13
(769 Views)
thank your !
the problem is solved.
Message 12 of 13
(747 Views)
If problem is resolved don't forget to mark Kudos.
Thanks and Regards
Message 13 of 13
(733 Views)
